1950 MH 44 Hydraulic Fluid and other odd questions
Bob Tredinnick
12-22-2002 18:59:09
Thanks to all for the help to date on getting my tractor working and running as good as it is. When I bought it, it came with a loader but it will only raise up about 3 feet. In hunting around I located what I belive to be the reservior behind the front grill and in front of the radiator. When I pulled the dipstick, the fluid is so low, it will not even mark the stick. My question is what kind of fluid does it use?
Another question is what is a good replacement shock that I can use on my seat. The current one is shot.
Last question, what is a good source for parts for a three point hitch. Mine seeme to be missing quite a few parts. Would anyone have a pic or diagram of what it should look like?
Thanks for the help
Lynch
01-05-2003 01:33:40
 Re: 1950 MH 44 Hydraulic Fluid and other odd questions in reply to Bob Tredinnick, 12-22-2002 18:59:09
I have an original MH 44 diesel parts book if you need it. Lynch
Jason
12-23-2002 10:40:23
For my seat I used a shock that goes on the cabs of semi trucks. The ones with the air ride cabs. The lenght was right, I just had to narrow the bushing on the shock a little bit.
marlowe
12-22-2002 19:45:20
the hyd. oil is just plain hyd. oil just get the weight for your weather temp. cold light hot heavy as for the shock they still make new ones its also the same one as IH used
