Mf60 tlb wont move
bcPA
12-24-2002 13:33:33
my friends MF 60 tractor loader back hoe wont move after the thing has warmed up. it is weak and will move after it has rested after night. any ideas as what to check or what might be the problem thanks in advance
Bob the Builder
01-01-2003 14:49:43
 Re: mf60 tlb wont move in reply to bcPA, 12-24-2002 13:33:33
I had a problem with my MF60 where after it was up and running the thing just stopped going in forward and reverse when it was in gear. Mine has a forward and a reverse drive pedal and the two pedals have a complicated linkage between the two. The linkage is quite worn and there are two cables that run from them. One for the engine throttle and the other goes to the trans. On mine I found the cable that runs to the trans was sticking and used some WD40 on the top of that cable and that linkage, freeing it up. Note that the trans cable gets pulled one way in reverse and the other way in forward and mine stayed stuck between the gears and the only thing that happened when depressing either pedal was I increased the engine speed only and the machine stayed stationary. All the hydraulics where operating ok. Had good luck with mine other that, and really thought at first the trans expired just when I had some 500 yards of fill being dumped off!
Just my 2 cents. Hope your problem is just as simple. LOL
Bob
Make mine a Massey!
12-28-2002 19:05:19
Torque Converter--my guess
