Will at Hitch All 3 pt really hitch up to all?
Bob Tredinnick
12-28-2002 18:08:11
Will be buying a massey harris hitch all three point for my 1950 44. My question is, will it really hitch up to most anything, or only massey harris equipment?
Thanks
Farmman
12-31-2002 04:26:35
 Re: Will at Hitch All 3 pt really hitch up to all? in reply to Bob Tredinnick, 12-28-2002 18:08:11
Where did you find the hitch? When I called hitch all last summer they told me that they did not offer a 3 pt. for a M-H 44. Or are you going to do some adapting to make it fit.
David B
12-29-2002 06:04:50
The 3 point hitch all is pretty much a category 2 hitch that interchanges with most three point equip. The biggest disavantage of the M-H hitch is the top link attaches to the tractor below the PTO and if you want to use a three point cutter you must raise the top link attaching to the tractor above the PTO and lengthen the top mast on the cutter so the top link is pretty much parallel to the bottom links
Casey McDonald
12-28-2002 23:26:24
If it is a regular three point hitch, it should link up to any three point implement. If it has two link arms and a top link hitch.
