Block Heater
MF35/Perkins - attn Ray Southern MD and Hawk
Chuck, WA
12-30-2002 09:28:48
I asked back in November about installing a block heater in my MF35/Perkins diesel. In replies to that post from Ray Southern MD and Hawk, the heater was installed in place of a freeze plug. Ray mentioned an O-ring, but neither mentioned threads and screwing the heater in. I bought the heater last week and it has threads. Did I get the wrong heater? Or, are there actually threads inside the freeze plug bore that you can't see with the plug in? I'm hesitant to start in until I know what I'll find since I don't want my tractor out of service while I chase down - or worse, have to wait for a special order for - the correct heater.
Thanks y'all...Chuck, WA
Big Dean
12-30-2002 12:41:16
 Re: Block Heater - MF35/Perkins - attn Ray Southern MD and Hawk in reply to Chuck, WA, 12-30-2002 09:28:48
Chuck you have the worn heater the freeze plug heater does no have threads. It has an O-ring that seals in the block & a long bolt & a cross piece that sets inside to hold it in place.
Chuck, WA
12-30-2002 13:49:04
 Re: Re: Block Heater - MF35/Perkins - attn Ray Southern MD and Hawk in reply to Big Dean, 12-30-2002 12:41:16
Big Dean...Thanks! Guess I'll take it back.
Ray, Southern Md
12-31-2002 07:36:33
 Re: Re: Re: Block Heater - MF35/Perkins - attn Ray Southern MD and Hawk in reply to Chuck, WA, 12-30-2002 13:49:04
Chuck,
Big Dean has you squared away on the proper heater type. When you take that unit back to the dealer. Open up the box with the proper one, and check the instruction sheet, to see if you are to put a lubricant around the o-ring. It could save you another trip out. It has been 6 years since I installed mine. I can't remember if they said not to use vasoline or you could use it. It may recommend another lubricant or maybe none at all.
Chuck, WA
12-31-2002 09:08:50
 Re: Re: Re: Re: Block Heater - MF35/Perkins - attn Ray Southern MD and Hawk in reply to Ray, Southern Md, 12-31-2002 07:36:33
Ray...thanks for the reply...and for the tip - will do.
