Oil leaks 270
ca
01-03-2003 08:18:25
I have a 270 massey fergurson tractor that I bought new. It has some oil and diseal leaks that I need to repair. Does anyone have any suggestions on what to do or how to go about this problem.
ted
01-08-2003 23:20:15
 Re: oil leaks 270 in reply to ca , 01-03-2003 08:18:25
What's leaking?
Diesel? Where? How much? If alot is coming from top of engine you probably had a return line come off.
Oil-
Power steering pump? Very possible. Probably leaking where the resivor meets the cast. Solution?? Ours doesn't leak enough to fix. Probably an o-ring or gasket at the connection.
Engine?
Trans?
Hyd.?
