Massey-Harris serial #
Bill in N.Carol
01-03-2003 20:23:55
I have a problem. My father in law has a Massey-Harris RC, and we are having trouble finding the serial # on it. Can anyone give me a location for this # ? The frame has been repaired with a patch plate, and the serial # may have been destroyed if it was there. If this is the case, is there another way to determine the serial #?
Alberta Mike
01-04-2003 07:32:52
 Re: Massey-Harris serial # in reply to Bill in N.Carolina, 01-03-2003 20:23:55
The serial number was originally on a tin oval plate on the tractors left side but obviously that's gone. It is also hand-stamped into the UPPER MACHINED SURFACE of the transmission/differential casting. It is between the castiron shifting platform and the steel plate that bolts down over the differential gears. It is on the left side of that surface, not too far from the where the clutch pedal sits. It will probably be filled with paint and gunk so you'll have to do some scraping. Meanwhile, describe the tractor, ie. tire size, hood/sidecover style, grille, engine, etc. That will also help. Once you find the serial number, post it here and someone will ID the model.
