TE20A S/N128084 HYDRUALICS WONT LIFT ?
BRIAN TAYLOR
03-21-1998 18:52:54
JUST BOUGHT A TEA20 RUNS GRREAT BUT THE HYRAULICS WONT LIFT .ALL FLUIDS ARE FULL NOTHING BENT OR JAMMING , PTO IS ON BUT NOTHING.... IM WILLING TO GET MY HANDS DIRTY BUT IS THIS GOING TO BE A BIG OR EXPENSIVE JOB ??. IF ANY ONE CAN GIVE ME SOME GUIDING LIGHT I WOULD APPRECIATE.. THKS BT
R. K.
03-23-1998 20:16:30
 Re: TE20A S/N128084 HYDRUALICS WONT LIFT ? in reply to BRIAN TAYLOR, 03-21-1998 18:52:54
: JUST BOUGHT A TEA20 RUNS GRREAT BUT THE HYRAULICS WONT LIFT .ALL FLUIDS ARE FULL NOTHING BENT OR JAMMING , PTO IS ON BUT NOTHING.... IM WILLING TO GET MY HANDS DIRTY BUT IS THIS GOING TO BE A BIG OR EXPENSIVE JOB ??. IF ANY ONE CAN GIVE ME SOME GUIDING LIGHT I WOULD APPRECIATE.. THKS BT
I have a TE 20 and I know your feelings. First, the obvious, do you have the PTO running - really turning. These tractors need the PTO running for the hydralics to be working.
Second, mine has this problem, every so often the metal fingers that run down inside the transmission and control the lift valve jump off the pins at the bottom of the valve. You can get them back on through the right side access plate. It may be easier if you drain the transmission first but I have done it with out draining also. It helps if you have small hands for this. Mine had jumped off about two or three times a year for a good number of years. I talked to a fellow last year who said he had used nylon tie strap to put some tension on the fingers just above the bottom end. I haven't tried this but might consider it.
Good luck.
