Big Dean need help with overheating on M-H 50
Brown Dirt Cowb
01-16-2003 19:29:29
I have a M-H50 that overheated. I replaced themostat. Today while blading snow it overheated and boiled over, tonight after it cooled down I refilled it with 50/50 mix and started it let it start heating up it pushed mix out of radiator, I did not have the cap on. The question is do I have a bad water oump or is it something else? Thanks for any help. Tom
Big Dean
01-16-2003 20:38:25
 Re: Big Dean need help with overheating on M-H 50 in reply to Brown Dirt Cowboy, 01-16-2003 19:29:29
Tom my first guess would be a head gasket leaking between the a cylinder & one of the water ports letting compression into the cooling system. It could also be the cores in the radiator are plug & you are not getting the circulation to cool the engine. If you filled it completely up to the top as the water heats up it will expand & run over especially with the cap off. That is my thought on it someone else may have something else though.
Brown Dirt Cowboy
01-16-2003 21:23:38
 Re: Re: Big Dean need help with overheating on M-H 50 in reply to Big Dean , 01-16-2003 20:38:25
Big Dean thanks for the quick reply. Now if it is the head gasket should I try to retorque the head or replace the gasket? I have owned this tractor for 14 yrs and overhauled the engine 8 yrs ago.The tractor was used for many yrs for lots of bushhogging but the last couple of yrs only used on my 5 acres. Wonderful little tractor only wished it was easy to mount a front pump on it so I could put a loader on it,have seen your posts in the past about the front pump and it does't look like much room available for mounting a belt-driven pump either. I will be awaiting your suggestion about the head gasket. Thanks Tom
