Mf 240 won't start in cold weather
bobby
01-18-2003 09:00:08
I have a 1985 massey 240, when it is cold outside (below 40*) the tractor will not start. It will just barely turn the motor over. I have a good battery with 1000 cranking amps, and when I turn the key over it pulls the battery down to about 6 volts. I have even tried jumping the tractor with my truck and get the same results. It will just barely turn over two or three times. I have checked all the wires and cleaned all the connections with the same results. I realize that A diesel is hard to start in winter but I can't even get the tractor to turn over. any ideas on where to start?
n-24
01-20-2003 08:57:00
 Re: mf 240 won't start in cold weather in reply to bobby, 01-18-2003 09:00:08
There could be a brake in the rear end of the starter so the starter cant turn after you release the key. In cold weather it can get the starter stuck or hard to turn. If it is the brake just remove it.
Lynch in E.TX
01-18-2003 16:03:59
I agree...somethings wrong with your starter. Have you thought about putting a block heater on the motor for the winter time starts? Lynch
Karl R
01-18-2003 11:30:15
I'm no expert, but it most likely seems to me that a shorted-out starter motor is the likely cause. If the voltage is dropping that much on a good battery then it's pulling out a lot of amps!
A siezed engine could put that much strain on a starter, but my guess is that it's a defective starter.
marlowe
01-18-2003 09:22:37
it sure sounds like a bad starter
