150 wont start
david
01-21-2003 16:23:23
My 150 mf will sometimes start on its own, but usually a small shot of ether is required. Just enough to make it spin faster than the starter will turn it. When cranking, I dont get any smoke out of the stack. Full of fuel,new filter and getting plenty of fuel at the pump when I bleed the injection pump via the screws on the side of the case but very little at the injectors .Throttle responce is a little sluggish and when you throttle it down, its erratic but ususally wont die.Has my govenor started to come apart? Checked my return line and am getting a small dribble with no air bubbles when running. Is it pump rebuild time? Thanks, David
Ray, Southern Md.
01-23-2003 06:43:23
 Re: 150 wont start in reply to david, 01-21-2003 16:23:23
Dave,
Check out your two air filters, inner and outer, they me be on the verge of clogging up. I remember that my respose with the trottle was also sluggish with dirty air filters. Take them out completly and see if the tractor starts better. Also, check the battery and clean all terminals.
Ray
