Massey 240 clutch
Bus Driver
01-24-2003 13:38:17
My non-Massey tractor has a plate on the side of the clutch housing for access for adjusting the clearance of the actuating fingers of the 2 stages of the clutch. I have no sevice info for the Massey. Does the Massey have any clutch adjustments possible (other than the pedal engagement point) without splitting the tractor? Any Web site devoted to this service info? Thanks for trying to help me.
Taiwan Levin Transport In
11-16-2003 19:05:04
 Re: Massey 240 clutch in reply to Bus Driver, 01-24-2003 13:38:17
Dear Sirs,
We are looking for the Gas Kits of Massey 240
Tractor with the following details:
- OEM No.: 36812127
- C&F Keelung, Taiwan
- Sample availability & cost
- Minimum order
- Delivery time
Please advise us a brief introduction about
your gas Kits.
Best regards,
Jack Du
Taiwan Levin Transport Inc.
Tel:+886 2 25850595
Fax:+886 2 25855207
Big Dean
01-25-2003 10:04:53
The MF240 has a PTO clutch adjustment that is made through the hole in the bottom of the bellhousing. If you have one of the loaders that has the rear mounting bracket covering that hole it will have to be removed before you can access the adjusting bolts. I have a picture showing how to make the adjustment. If you want to email me I will send it to you
Bus Driver
01-25-2003 10:22:38
 Re: Re: Massey 240 clutch in reply to Big Dean, 01-25-2003 10:04:53
Thank you for the generous offer and for the Website. Tractor people are such fine folks- and Massey's are fine tractors!
