Snow-blade on '48 Massey Harris Pony
Alex von Niebel
01-29-2003 12:56:13
Several months ago, I purchased a MH snow-blade for my '48 MH Pony. The previous owner indicated that the only way to lift the blade up and down (frame-mounted) is if the Pony has front hydraulics.
Instead of using hydraulics (which I do not have on my Pony), does anyone know if the front manual lifting arms on a Pony can be used to lift the blade up and down?
Does anyone have a Pony with a snow-blade using manual front lifting arms to lift the blade up and down?
If so, it would be great if you had a close-up picture or a photocopy of a manual that would show me.
Thanking you in advance.
Alex
rod
01-30-2003 04:08:19
 Re: snow-blade on '48 Massey Harris Pony in reply to Alex von Niebelschutz, 01-29-2003 12:56:13
I had a snow blade set up it had a big counter weight that went on back to offset weight of blade I do not have it now and did not have it on a tractor.
regards
rod
scotts
02-10-2003 22:22:19
 Re: Re: snow-blade on '48 Massey Harris Pony in reply to rod, 01-30-2003 04:08:19
my father in law has a 35 with a snow blade- it is lifted by cables and puuleys that attach to the 3 point hitch in the rear- looked like a job to install but it seemed to work fine
maybe your plow could be set up the same way
