1962 MF35,Gas, Slight miss in motor,jerky hydr.
Spence
02-04-2003 11:49:14
My gas MF35 has a slight miss in the motor and was wondering what the possible cause could be.
Also ever since I've had it I noticed that on the up hydraulic, the movement is jerky. By that I mean quick little jerks and not visible on the lift rods, but more felt when holding them. My gut feeling is that it's normal.
Thanks
CH
02-04-2003 13:45:46
 Re: 1962 MF35,Gas, Slight miss in motor,jerky hydr. in reply to Spence, 02-04-2003 11:49:14
Hi Spence,
Slight miss: Plugs, Plug wires, Distributer cap, points, condenser or ignition timing.
Jerky Hydraulics: filter might need cleaning and check the color of your hyd. oil. If it's milky, change it. Big Dean says Permatran before you ask.
Good luck. Charlie
