off the land
02-10-2003 11:24:29
Re: How rare are wide front M.H. 444s? in reply to Bluesman, 02-10-2003 08:04:50
They look great, but 45 years proves many wear parts. The wedges oval out the adjustment holes, pulling sample bushings and bearings will let you match at a supply house. Tie rod ends: try Tisco, MF 35 & F40 will retro-fit. The sector gear is a pricey task: dress at a machine shop? If the steering support housing is hack welded, best to go 'pro', or nearly drive over the front wheels, when it snaps on a hole. Steering box always needs a rebuild, worm shaft problem:zero parts, all the NFE & Standards are reverse direction. Add yet another layer of confusion, if you have WFE with factory PS:machine shop fabrication parts $$$. Great Hi-Arch tractor, but the scant two year production, with no R & D budget, left the bugs to the buyers. Parts & Pro welding can run a quick 400. The question is not how rare, but how many have been converted, to NFE, from parked Triples and Specials? All M-H production figures are subject to dispute. Those 361(?) '58 444's, are outsourced parts inventory, vintage late '57. As the song goes:"nothing was delivered". Possibly the most beautiful tractor of the century.
