this has been a dandy tractor for the 5 yrs or so have owned it, until a couple of months ago it began running roughly and worse so that it would only run slow and maybe not very long and only with the choke perhaps half way out.earlier in this sequence, i noticed some red gunky-looking stuff and cleaned the bowl out. then, it seemed to run ok only if i left the bowl holder so loose it would leak; if i tightened enough to stop the leaking, it would start sputtering and then only run with the choke routine. did put in new bowl gasket, and may have helped some. after cleaning carb (no kit), draining gas tank, new plugs (helped some -- old ones fouled because of the choking), and new coil, the same basic problem remains. i don't see any cracks in the pot metal glass bowl holder and valve at the bottom of the gas tank. could there be enough of an air leak between the gas tank and carb to cause this? how much vacuum is there in this continental gas engine with a zenith carburetor? in other words, i haven't really got to the problem. any comments would be greatly appreciated. thanks
