1100 Massey Transmission
mike
02-13-2003 14:19:53
I have friend whos 1100 died on him so he threw it in park going down BIG hill what has he tore up in the transmission. Any help is greatly appreicated as i'm a jd man and masseys are new to me thanks mike
Charlie
02-13-2003 17:53:03
 Re: 1100 Massey Transmission in reply to mike , 02-13-2003 14:19:53
Did park work before this event?
The parking brake has a paw with several teeth that mate up with a gear on the pinion. The paw is located behind the left fuel tank under a access plate about 4X6 inches. Before you take access plate off you need to drain trans/hyd oil.
What happen when tractor was put in park?
One possibility is that the teeth on the parking brake paw were destoried. If the tractor is stuck in park, try pulling tractor forward and take it out of park. IF necessary try pulling backwards and take out of park. Where are you located? Charlie/San Antonio
