MF Super95 trouble.
chris k
02-13-2003 19:42:16
We have a Super 95 Massey that is not running right. We left the tractor idle at about 1000rpm for 1/2 hour and came back and found that diesel fuel had covered the hood. The diesel fuel is coming out of the exhaust pipe. The tractor does smoke quite a bit even when the engine is warm. We think this smoke may be fuel that is not combusted properly. All the injectors have been rebuilt and the pump(Roosamaster pump) seems to be operating fine. Compression of all cylinders are within 35PSI of eachother. Does anyone have an idea of what is going on with this engine? Thanks in advance for all replies.
JK
02-13-2003 20:00:52
 Re: MF Super95 trouble. in reply to chris k, 02-13-2003 19:42:16
Chris,
It sounds like either the engine has very low compression or more likely the energy cells need to be removed and cleaned. The I&T manual has info on how to do this.
John
