135 shifter knob changes
gregg
02-15-2003 19:38:51
does anyone know when MF changed from round shifter knobs to the R-1-2-3 and H-L pattern. My 135 has no ID plate but does have original round knobs. Maybe the change time can help to date the tractor. Or if you know of any other indicators as there are "wings" on where the lights join the tractor
Don-WI
02-15-2003 22:42:08
 Re: 135 shifter knob changes in reply to gregg, 02-15-2003 19:38:51
My 165 has the shift pattern cast into the trans. case, just below the shifters. If yours has a good build up of grease you may find the pattern underneath that.
Donovan from WI
jerryinid
02-15-2003 20:35:01
Gregg
Check with your MF dealer. There should be a decal that goes on the dash that shows your shift pattern. Hope this helps.
gregg
02-17-2003 07:47:02
 Re: Re: 135 shifter knob changes in reply to jerryinid, 02-15-2003 20:35:01
What I am trying to find out is if there was a specific date that MF changed from the round knobs to the labeled ones. This could help me date my 135. Thanks for the help.
