Pacer 1955 w/continental Y91 fuel pump or gravity feed fuel
Bob LaBrie
02-22-2003 13:02:05
My Pacer did not have a fuel pump when I acquired the tractor. However, the Y-91 continental engine block has space to accept what appears to be a fuel pump. Currently, the fuel is gravity feed but at times the rate of fuel is not adequate.
Does the Pacer has a fuel pump? If so, what is the partnumber and maker?
Thanks, Bob
John
03-01-2003 17:15:45
 Re: Pacer 1955 w/continental Y91 fuel pump or gravity feed fuel in reply to Bob LaBrie, 02-22-2003 13:02:05
No the pacer didn't have a fuel pump. Sounds like you have a clogged line or sediment bowl screen.Take the line off the carb and see how much gas flow you have. Hope this helps John
