Massey Harris 303
Barry Flint
02-24-2003 15:31:46
Hi! am new to this site and am desperate for help. I have a MH 303 "Work Bull" industrial tractor w/loader and backhoe. I use this tractor nearly everyday in some capacity around my mobile home park. I just twisted a rear axle off and am trying to decide what to do. Will other MH parts (such as 44 standard)interchange? Thanks, Flint
marlowe
02-25-2003 09:35:38
 Re: Massey Harris 303 in reply to Barry Flint, 02-24-2003 15:31:46
i sure would try a axle out of a 44 std. seeing they are of the same age and massey did interchange a lot of parts eaven the axle out of a plain 44 might work if you change hub. if close to wi. i know of axles
Barry
02-25-2003 20:44:27
 Re: Re: Massey Harris 303 in reply to marlowe, 02-25-2003 09:35:38
I found a 44STD diesel with a bad engine for $500 and took some measurements today.It looks like the axle itself may be bigger around than mine. I could possibly use the whole tractor, but the rear wheel stance is narrower and won't accept my loader. Someone else suggested a 33 or 333 axle might be the same, but don't know yet. Mine has the big nut on the end to hold wheel on. P.S. I'm in sw Mo. Thanks, Barry
marlowe
02-26-2003 04:56:47
 Re: Re: Re: Massey Harris 303 in reply to Barry, 02-25-2003 20:44:27
what size axle do you have no.of spline lenght dia.?
