MF 35 delux oil driping....
a j johnson
03-02-2003 07:35:06
Out the bottom of the bell housing and the sides of the case where the clutch pedal bolts to the shaft and the other side of the case too.I figure i have a bad seal some where inside.Can i fix this my self? I must have to split the tractor to get in there so any help would be welcome .Thanks ,
aj johnson
03-07-2003 04:21:45
 Re: MF 35 delux oil driping.... in reply to a j johnson, 03-02-2003 07:35:06
thanks all,,i have a gas engine z134 and i think the oil is comming from the engine so i suspect a rear seal,,time to get dirty i guess,? will the clutch need to be replaced?
Ricky in NC
03-02-2003 16:37:47
Sounds like a seal from the transmission or possibly a rear main engine oil seal. Does it look like engine oil or transmission oil? Does the leak increase when the engine is running with tractor sitting still? I believe you have to break the tractor in half to get at these seals.
Bob
03-03-2003 22:47:59
 Re: Re: MF 35 delux oil driping.... in reply to Ricky in NC, 03-02-2003 16:37:47
If it is a 3 cylinder Perkins diesel, and it is engine oil leaking out the hole (you can tell by the smell of the oil) you fix it by replacing the rear engine oil seal.
If it is this problem, get new gaskets and drop the sump. The front and rear oil seals are thick gaskets and should be fitted carefully and glued in with aviation type gasket cement. Getting the seals in right takes time and patience. The sump oil seals are easy.
Be prepared to get very dirty. After removing the sump oil will drip for a long time and there is no alternative but to get right underneath to put the gaskets in. Also make sure you block up the front of the tractor and the transmission housing so you can work safely. I would hate to be pushing those gaskets in without everything safely jacked and blocked up.
