Cracked TO 35 block
Bob Voreis
03-03-2003 13:14:53
I have been given and estimate of $400 to weld my block that is cracked between three cylinders. They say they will waranty it but it seems like a very high price and I wonder if anyone else has gone through this and would have advice for me? The motor is a Z134-402294. I have no idea what cracked it it was working fine and all of a sudden I found water in the oil.
Bill V
03-04-2003 16:38:17
 Re: Cracked TO 35 block in reply to Bob Voreis, 03-03-2003 13:14:53
Unfortunatly Ferguson tractors are known for cracking the blocks between the cylinders. I had a TO-30 that I was getting water in the oil but it was the o-rings on the sleeves that had deteriorated and caused it. Ferguson blocks were to thin between the cylinders and would crack from the heat or the o-rings on the sleeves coming apart and letting water in and the freezing if not caught in time. You could try to find another block but that can be pretty hard to do, and thier usually expensive. Good luck
Damon
03-04-2003 15:02:39
Bob,
try posting your question on the H. Ferguson discussion forum for more answers.
Damon
