333 Massey
Darrell Clarke
03-03-2003 19:11:22
I recently purchased a Massey Harris tractor, the tag on engine states that it is a 333. Is this a well known tractor or is there few of
them around today?
Thanks for ANY help
Darrell
Darrell Clarke
03-04-2003 15:49:44
 Re: 333 Massey in reply to Darrell Clarke, 03-03-2003 19:11:22
To: MARLOWE Thanks for the information. I used the tractor last fall until the weather closed in. Since then it has been parked. I will check it(the I.D. #) and let you know what I find. Again, thank-you for your help.
Darrell
marlowe
03-03-2003 20:31:28
tag on the engine that says 333 boy never seen that? there are not a real lot of 333 only made 2 years 1956 and 57 total prod.2644 in 56 100 in 57. the id tag is on the left side of the frame just ahead of the clutch peddel engine id is right front of the block at the head line should have H208 stamped in the block if the engine is not oem it might be a H260 or H277
