Hydrolic accesories
charlie
02-07-2000 20:07:24
i want to add a hydrolic setup to operate a snow blade on the front of my MF135 (1973). i have an external twin spool valve for control and all the hydrolics (lines and cylinders) for the blade. i believe that my tractors hydrolic pump can supply what i need. there should be an external tap in point that can run this system. i think the blade runs a open loop and the control just diverts oil. what i need to know is where to tap into pump supply from my tractor and where to return it.
Clarence Carhill
02-08-2000 04:54:04
 Re: hydrolic accesories in reply to charlie, 02-07-2000 20:07:24
Hi Charlie... On top of your transmission case in between your legs back near the seat is a square cast iron cap with two bolts holding it on. You will need to purchase a diverter valve and mount it on there. This will allow the hydraulic oil to be diverted to your system rather than the three point lift arms. The sad thing is... you can not use your three point lift arms at the same time you use your snow plow....
