101JR
chuck Ore.
03-12-2003 07:10:29
I picked up a 101JR i'am an IHC guy but couldn't resist the challenge.Are These tractors pretty common model like a Framall H It appears to be a simalar tractor Thanks chuck ore
Alberta Mike
03-12-2003 09:49:42
 Re: 101JR in reply to chuck Ore., 03-12-2003 07:10:29
Massey made the Junior series on the same tub and chassis as their Senior (6 cylinder) tractors. Do you have a serial number? There were early and then later versions of the 101/102 Juniors with some differences in sheet metal, etc. I have two 101 Juniors (early versions). Nice little tractors, easy to work on since the engine and clutch assembly can be lifted out without splitting the tractor. The engines are Continental flatheads and parts are readily available. Post back if your tin plate with the serial number is missing from the left side of the tractor.
chuck ore.
03-12-2003 10:22:50
 Re: Re: 101JR in reply to Alberta Mike, 03-12-2003 09:49:42
My # is 505502 did they make a whole lot of these?
Dave_Id
03-15-2003 12:56:05
 Re: Re: Re: 101JR in reply to chuck ore., 03-12-2003 10:22:50
Around 26500 101 and 102 Juniors of different configurations.
