150-worth?
Don-WI
03-15-2003 18:31:01
How much is a 150 worth? It's a 3 cyl. Perkins deisel, good sheet metal, paint is ok. Lights work, has 9.5L 15 implement tires on front and Utility rears, about 70%. Runs good, but clutch needs adjustment. Steering seems tight, but may also be low on fluid or a bad pump, steers hard unless higher RPM's. Had about 60 lbs oil pres. Seemed like a fairly solid machine.
Donovan from Wisconsin
