40B Steering problem
Greg
03-19-2003 20:29:40
I have A 40B backhoe that when you turn the steering wheel to the left everything works but when you turn the steering wheel to the right nothing happens, the steering wheel just turns and turns, but the front tires don't move
Sometimes if you lower the front bucket to lift the front wheels up then it works or if you turn it back to the left then the right again, it sometimes works
Any ideas of what is happening???
Thanks Greg
Leo
03-24-2003 12:54:44
 Re: 40B Steering problem in reply to Greg, 03-19-2003 20:29:40
Hi Greg, I have a 40B with a similar problem. However recently I realized that my problem was not hydraulic, simply however the "keys" and or Key ways are shot on my tractor. Next time the steering seems not to be working, look at the front end and see if the steering is not working, or if the caps are turning and the tires are not? This is what has happened to mine. I am currently waiting for time to take the front end apart and see what's left of the key ways to see if i need new spindles too.
Good Luck,
Leo
CH
03-20-2003 04:15:37
Go to the following website and read the second paragraph about steering.
Link
Good luck.
greg
03-20-2003 05:10:15
 Re: Re: 40B Steering problem in reply to CH, 03-20-2003 04:15:37
Thanks
I'll take a look.
Greg
