Battery Size Question
Bill
03-25-2003 19:07:35
Can someone verify the battery size for my MF50 diesel (Perkins A3-152)? I think it is the same as the MF35 w/ same Perkins diesel.
I believe I need a Group 31 and 950 CCA battery. Is this correct?
Thanks!
Bill
Boss Hog
03-28-2003 08:04:40
 Re: Battery Size Question in reply to Bill, 03-25-2003 19:07:35
I went into the local part place and told 'em I wanted a battery that was so big the engine would slow down when it started.
I absolutely HATE it when something doesn't start when I need to use it.
Stay away from the $39.95 batteries, and get a good one - Should run you about $75 or so.
Don-WI
03-27-2003 20:33:28
In my opinion, you can never get too big of a battery. Just more cca's on those REALLY cold mornings where it just doesn't want to start, and you have to crank for a while. Also make sure it fits in the battery box, that's the only other thing that's important.
Donovan from WI
klf
03-26-2003 19:40:11
I believe the battery recomended by Massey was the 29H. HOWEVER, the 31P-PHD is the exact same size and has 300 more CCA. I replaced all my 29H batteries with 31P batteries, and no more battery problems. Go with the 31P.
Note!! 31 is stud terminal, and 31P is post, you want 31P!!
Bill
03-28-2003 18:37:15
 Re: Re: Battery Size Question in reply to klf, 03-26-2003 19:40:11
Thanks! I picked-up a group 31 battery, 950 cranking amps, and it fit nicely in the tractor. BTW, good point on the 31P. The battery I bought has the terminal studs, but they are OK. Next time around, I plan on getting, as you suggest, the post terminal (something I like about lead!) and refitting my MF50 diesel with #1 or #0 gauge battery cables.
Bill
Paul in OZ
03-26-2003 02:59:39
Your battery supplier should have a catalogue to ensure your tractor gets the correct size battery.
