MF 135 blowing oil out of dipstick
Chip Hildreth
02-09-2000 20:19:47
I did not notice that the fuel had frozen in my tractor ( it got down to 1F ). The fuel ran dry, I used starting fluid to start it. Tractor ran fine for a while and I noticed that oil was coming out of the dipstick. It does not run rough, but I need to check the compression. What should it be for a 135 diesel? Thanks, Chip....
John
02-16-2000 08:15:17
 Re: MF 135 blowing oil out of dipstick in reply to Chip Hildreth, 02-09-2000 20:19:47
You could have a hairline crack on a piston, and it could still run fine for the time being. The extra gasses should come out your draft tube but a restriction there would push oil out the dipstick.
Gerald J.
02-10-2000 07:25:43
You also need to remove the mud dawber's nest from the vent pipe running from the rocker arm cover.
Gerald J.
