PAINT CODES FOR MH
CHUCKCAT4
03-26-2003 23:23:19
I WANT TO PAINT MY MH TRACTORS BUT I NEED TO KNOW WHAT THE ORIGANAL COLORS WERE IF SOME ONE HAS A PAINT CODE IT WOULD BE VERRY HELPFULL THANKS!
Bill Hires
03-27-2003 04:39:18
 Re: PAINT CODES FOR MH in reply to CHUCKCAT4, 03-26-2003 23:23:19
PPG Code for Massey Harris red is 70364, yellow is 80533. DuPont code for Massey Harris red is (Before 1957)018, or 674U, yellow is 29440(M1023). DuPont lists seven other red codes depending on the model and year.
off the land
03-27-2003 14:48:22
 Re: Re: PAINT CODES FOR MH in reply to Bill Hires, 03-27-2003 04:39:18
The Dupont "Industial" line gives good results in all application methods. Since the 44 has so much casting, a brush works well on the axle housings,
transmission case, as you assemble. Obviously, all
the sheet metal does best, sprayed. The yellow was
questionable, as titled MHF YELLOW, not 'straw yellow'. Since the MH badge stayed on the combines
through 1962, this may be the MHF yellow. Dupont
matched the 1955 yellow, after we removed a front
tire from the rim. Paint looked decent in the rim
so they matched it. Seems all replacement decals
are the wrong yellow, more confusion. Good luck.
