What size Grader Box
Charlie
03-27-2003 08:46:25
I have a MF 165 dsl. I am interested in gatting a Grader Box but not sure of what type?? of size I should get. I am interested in one that will not come apart or bend up after a few uses. I like to get something heavy duty just because thay are usually built better. What are your oppinions.
Thanks for your help
Charlie
Yankee in Tn.
03-30-2003 05:40:46
 Re: What size Grader Box in reply to Charlie, 03-27-2003 08:46:25
I have a MF35 Deluxe gas,and a 6'box blade.The tractor does fine ,it will easily pull a full load of anything.Your 165 should have no problem with a larger box.There is such a thing as to big depending on what you are going to use it for.Try to find one that is just wider than your tractor.
