Value of a 44-6
Black Creek Far
04-07-2003 18:30:33
What is a running 44-6 worth with a w/f ? It smokes a little but has plenty of power. It needs a few things but we use it regularly. I need live power and hydraulics so need to sell it. The hood has been cut away a little above the broken exhaust manifold . Would need a few things to make it pretty.
off the land
04-08-2003 10:04:24
 Re: Value of a 44-6 in reply to Black Creek Farm, 04-07-2003 18:30:33
There's been one selling for high prices on e bay,
in PA. Problem seems to be the bidders must forget
two things, inspection and good credit. The post
mentions 'deadbeats', less than perfect. A new
buyer, no money exchanged, at premium price. The
44-6 is then relisted. Figures in the high teens.
Throttle and front wheels from a Special, it's a
late six, by S/N, '50-'51. It runs, at least, the
44D on e bay has coolant in the oil, over $900.
One fresh engine, please.
marlowe
04-07-2003 20:18:16
hay black creek farm are you in wi.? if you are i would like to look at the 44
STEVEN H
04-08-2003 11:29:58
 Re: Re: Value of a 44-6 in reply to marlowe, 04-07-2003 20:18:16
Marlowe you are here in wisconsin? i had now idea, where's abought? just not of west bend my self!
marlowe
04-08-2003 12:33:43
 Re: Re: Re: Value of a 44-6 in reply to STEVEN H, 04-08-2003 11:29:58
fremont just west of appelton MASSEY COUNTRY any pulling around west bend? not real massey country more jd but they don't touch my 44 special
STEVEN H
04-08-2003 14:22:48
 Re: Re: Re: Re: Value of a 44-6 in reply to marlowe, 04-08-2003 12:33:43
well you are more than welcome to come pull with me at washinton county fair. and they have one at the ozaukee fair to. big one in ozaukee. that 44 specal is almost unbeatable. only one tractor have i ever seen beat a good massey. and that is the minnie moe utu. plenty of massey round hear, but also to many deere.
marlowe
04-08-2003 15:39:48
 Re: Re: Re: Re: Re: Value of a 44-6 in reply to STEVEN H, 04-08-2003 14:22:48
will you please post the dates on the pulling board when you get them THANKS we had 12 or so in class sunday on a in door pull out pulled the 2nd place tractor by 24ft. 6in but got DQ over a 9 in peace of rebar to hold a weight on they called it a bracket other then that she is 100% stock in my book power don't mean sh__ __it all in set up and reading the track dirt or blact top
STEVEN H
04-09-2003 07:37:33
 Re: Re: Re: Re: Re: Re: Value of a 44-6 in reply to marlowe, 04-08-2003 15:39:48
I will post them when i get them. as for that bit on the rebar deal well that is bogus. what kind of wieght do you put on the 44? i am going to run my farmall H this year. next year i hope to have my 44 rebiult. it some times doesn't have the power to make it up a hill in first. needs an o/h bad.
marlowe
04-09-2003 14:32:01
 Re: Re: Re: Re: Re: Re: Re: Value of a 44-6 in reply to STEVEN H, 04-09-2003 07:37:33
my 44s is 5220lb with cast rear wheels dry and no cast wheels on front i was going to pull it in 5000 and 6000 but i have a bad back and can't handel the weights so i just do 6000. so i load 780 lbs on her with my pickup truck cheery picker but if i get ride of the cast rears then i have to load 1280 and can't find the room where it should go. as for the DQ i had the cast front hubs hung on by rebar. latter
marlowe
04-07-2003 20:18:03
