1080 problems
Jim
04-14-2003 08:36:12
I have a 1080D that will only start if you jump the starter. The key switch works fine in my 1130 and the neutral saftey switch works fine. Also, when you use the multipower, only low works. It also has dual remote hydraulics that work fine. Does anyone have a wiring diagram for one of thses? If you got one, could you please e-mail it to me?
Don-WI
04-14-2003 22:07:40
 Re: 1080 problems in reply to Jim, 04-14-2003 08:36:12
Check the selenoid, chances are that could be bad. Are you saying you took the switch out and put it in another tractor? if that's the case, it sounds pretty solid chance of it being the selenoid.
Donovan from Wisconsin
Jim
04-16-2003 11:10:10
 Re: Re: 1080 problems in reply to Don-WI, 04-14-2003 22:07:40
Don. I took the key switch out of my 1080 and put it in my 1130. Do these tractors have clutch safety switches too?
Don-WI
04-16-2003 18:15:35
 Re: Re: Re: 1080 problems in reply to Jim, 04-16-2003 11:10:10
Pretty sure they do, all massey's i've seen have anyways.
