270 massey lift
Donnie
04-14-2003 12:18:06
My 3 point hitch hitch will only work with the tractor ideling, if you accelerate the lift will fall back down. It hicups but the fluid level is full. It has a loader on it and it works fine. any idea what the problem could be?
howard
04-16-2003 15:10:01
 Re: 270 massey lift in reply to Donnie, 04-14-2003 12:18:06
You need to check under the seat and there is a little lever (on top of the trans housing) If it is up push it down or vice or versa. Can't remember which way it goes but I do know when in one position it puts all hydr pressure to remotes and the other way it feeds both the 3 point and remotes. I leave mine in the later postion and it runs the loader fine (that way I can carry bale of hay on each end. Check your owners manual and it has a picture of the lever I am talking about
Jim
07-29-2003 13:37:11
 Re: Re: 270 massey lift in reply to howard, 04-16-2003 15:10:01
need to change the filter in the intake to the hydraulic pump, the first pump is pulling a vacuum and the lift pump can not pickup any fluid. You can clean the filter but may not work had to replace mine.
