165 Diesel Charging Questions
Jamie
04-14-2003 18:48:42
I bought a new alternator which had a smaller pulley than the existing one. I took the small pulley off the existing alternator and put it on the new one and installed it. My amp gauge shows zero at idle and 30 amps at 1000 RPM's. At idle my voltage is 13 volts, at 1000 RPM's my voltage is 15 1/2. It never cuts back at high RPM's but it used to. How do I tell if the new alternator has a built in voltage regulator? The alternator has a battery terminal, F terminal,R terminal and ground terminal. I wired it the exact same way the old one was. Could it be a bad voltage regulator under the dash?
Thanks.
Don-WI
04-14-2003 21:55:36
 Re: 165 Diesel Charging Questions in reply to Jamie, 04-14-2003 18:48:42
15.5 isn't a bad thing. A new 12 volt battery actually has 12.6 volts. When an engine is running, the alternator is always putting out anywhere from 12.6-16 volts. I think 16 is a little high, but I can't remember actual #'s. I wouldn't sweat it, but it it makes you feel better buy a new regulator for it. Most companies would probably recommend it anyways.
Donovan from Wisconsin
John Manders
04-17-2003 06:12:02
 Re: Re: 165 Diesel Charging Questions in reply to Don-WI, 04-14-2003 21:55:36
Alternators should govern at 13.8 - 14.2 volts. 15 volts is too high.
John
