MF 135 HOLE IN OIL PAN
CHRIS
04-19-2003 07:01:19
BOUGHT A MF135 WITH GAS PERKINS. HAS CRACK/HOLE IN OIL PAN LEFT SIDE NEAR BELL HOUSING. NOT SURE WHAT HAPPENED,IS THIS A COMMON THING WITH PERKINS? IS IT HARD TO FIX,MUST LIKELY A BROKEN PUSH RODE. WILL THE OIL PAN FROM A DIESEL FIT THE GAS PERKINS? THANKS
Bob
04-24-2003 17:57:57
 Re: MF 135 HOLE IN OIL PAN in reply to CHRIS, 04-19-2003 07:01:19
The diesel will fit, I am sure, same block. I would not patch w/ epoxy. The pan is a structural part of the tractor! Could be a disaster! As I recall, you have to pull engine to swap pan. Good time to do an overhaul. Parts are inexpensive, and easy job to do!
David
04-20-2003 22:09:09
Don't know if it would fit but would patching with JB weld do to repair old one?
