Continental engine parts
Arnie Alt Jr.
02-11-2000 17:08:43
Need to find some sources for continental engine parts as used in Massey Harris tractors. Thanx Arnie
Lois
02-23-2005 07:07:19
 Re: continental engine parts in reply to Arnie Alt Jr. , 02-11-2000 17:08:43
Help!!
I have a Massey Ferguson tractor with a 145 continental engine. The distributor is bad and it has no numbers on it. The new distributors do not work--can anyone help.
floyd a. harwell
11-28-2001 07:18:12
I NEED TO FIND THE LINKAGE FOR THE GOVENOR ON A CONTINENTAL ENGINE ON A DAVID BRADLY TWO WHEEL WALKING TRACTOR. THE NUMBERS ON THE ENGINE PLATE ARE AU7B 127101A.
Tom S.
02-14-2000 06:40:12
Last account I had, Continental was bought and being handled through a company called WIS-CON TOTAL POWER, in Memphis Tn. I had the number and address at one time, but can find it if need be. They had all the odd hard parts like timing gears, crankshafts, even some replacement blocks for tow motors and industrial equipment. Tom S.
bill elliott
12-24-2000 14:51:06
 Re: Re: continental engine parts in reply to Tom S., 02-14-2000 06:40:12
i have a 44 Special diesel, the block is cracked, and I am looking for a good used block. Any suggestions or leads would be greatly appreciated.
We live in Ontario, Canada so Canadian places would be best, but it doesn't really matter either way. Please e-mail me back at billandkaren@sympatico.ca
curtis perry
02-13-2000 14:17:44
as far as i know you can buy most parts through "napa" auto parts stores hope that this helps
jim
02-12-2000 21:59:00
I just went to an old established auto parts here in town(salinas,ca) and asked for continental engine gaskets. They pulled out an old continental parts catalog and got me everything I wanted. I got all the engine gaskets and a rebuild carb kit for a marvel schebler tsx-43. The carb kit was 20 bucks and I paid about 40 for the head gasket, oil pan,front cover and side cover gasket. They had everything in stock! ELMER'S AUTO PARTS---831-758-3321
Vern Novak
01-01-2002 06:52:22
 Re: Re: continental engine parts in reply to jim, 02-12-2000 21:59:00
I'm looking for a parts supplier in the Phoenix area for an FS244 Continental engine. Rings & gaskets in particular.
Sylvain Veilleux
10-22-2001 19:07:49
Im looking for a Caterpillar tractor engine crankshaft. TRactor series #9U25077 and crank stamping # 3F5020
Brad Moss
04-25-2001 05:13:06
I am working on a 1927 Star which has a continental engine. Can any one tell me where to get tune up parts for this engine?
Rodney Magee
07-22-2001 18:09:23
 Re: Re: Re: continental engine parts in reply to Brad Moss, 04-25-2001 05:13:06
Check with Montes Equipment Company. You can do a search for Continental tractor parts and it will bring them up.
Mike from Ontario
02-12-2000 15:22:33
Arnie
I usually get my parts from Sealed Power And Hastings from a local UAP/NAPA dealer, If you let me know what you are working on i can get the part #'s for you Mike
B.C.
02-12-2000 07:43:18
When I wanted some fresh con rod bolt washers for the Z134 in our MH50, I tried contacting Continental. I was told to go talk to MF, they handled parts for those engines. So I did, ordered them through the nearest dealer and had them UPS'd to me directly within 3 days. This was mid 1980's.
I was finishing up an engine overhaul with a rebuild kit that I had gotten from Central Tractor. Those parts worked just fine, but there was the odd thing like said washers that Massey sold.
Napa is good for ignition service parts. I dunno if they do carb rebuild kits, but Central Tractor does. If your starter, generator and voltage regulator are Delco, most automotive electrical shops can rebuild or replace those parts adequately and as cheap as anywhere else.
John
02-12-2000 06:18:21
Try napa i get parts there for my MH pacer. John
bob
12-11-2000 12:03:57
 Re: Re: continental engine parts in reply to John, 02-12-2000 06:18:21
sure glad got in here ihad lost monte,s phone no. he gives real good service
Edward Leahy
02-13-2002 12:30:38
 Re: Re: Re: continental engine parts in reply to bob, 12-11-2000 12:03:57
Looking for a price on a rebuilt continental 4 cyl its on a lincoln welder model no 200 FA. Also a pric on a short block for same. thank you.
