Help with uk 135
chris mf35
04-26-2003 19:49:51
bought me a new tractor last week. a 1966 uk 135 ad3-152,rops,canopy, 80% rubber, no ps(can't win them all). i need some info on the uk's please
1. what is the steer adjustment steps?
2. need wiring diagram please,it'sway diff from us models. complete sys shot.need total rewire.
3. need sourse for tach. it runs ccw
4. have heard hp is diff, what is it rated?
5. bleeding steps. does not have lever on lift pump.section in us it manual not applicable.
5. anything else i should know about this tractor? thanks Chris
David
04-27-2003 15:05:09
 Re: help with uk 135 in reply to chris mf35, 04-26-2003 19:49:51
Tacho available from several UK suppliers. Best bet is to look at directory of suppliers on Friends of Ferguson webs site (should be able to pick it up with a search) Don't know if there are US sources but I expect there would be.
To bleed fuel system without lever on pump, you will probably have to crank engine. (any chance lever is just missing?) You open bleed screw (or any thing that will let air out really) on top of each of the fuel filter(s) in turn until fuel flows then tighten. Then open bleed screws on side of injection pump and crank engine again(top one first I think is correct but in my experience it doesn't seem to make much difference as long as you're getting fuel out) Tighten them when fuel flows. Then open fuel unions at injectors slightly and crank till fuel comes out there. (remember to have stop control at "run" position) When you're getting fuel at the injectors you can tighten them up and it should start usually immediately. If you're getting white smoke from the exhaust while cranking the engine is probably getting fuel ok.
ray-s
04-27-2003 12:04:03
Link
There are wireing diagrams at this website. Along with other useful info.
mike
04-27-2003 07:06:38
Massey Ferguson 135
Engine: 3 cylinder diesel, 47h.p.
Transmission: 6 forward and 2 reverse gears (optional Multi-Power doubles gear range).
Tyres: Usually 11-28 rear and 6.00-16 front.
Steering: Conventional, power-assisted optional.
hope this helps
