'58 MF 65 3pt No lift with load
Adam
05-01-2003 21:02:35
Symptoms: Will operate with nothing on lift arms, other than that, won't lift a thing over 40 pounds. The three point will barely lift an empty boom pole. Any thoughts???? I know that the fluid needs to be changed, as I did discover water after it had been running a while. During the initial dipstick check it seemed OK. Then noticed the milky-ness and stopped for the day. Any ideas will be great.
Thank you so much,
Adam
Paul in Oz
05-06-2003 06:02:53
 Re: '58 MF 65 3pt No lift with load in reply to Adam, 05-01-2003 21:02:35
Have you tried replacing the hydraulic oil filter. Sounds to me like the oil has gummed up & the filter is blocked. It's a cheap & easy fix if its the problem. Not a bad place to start anyways. Godd luck, let us know how you go.
Lee
05-03-2003 12:06:52
Another test you can do is put something on the PTO first and see if it stops under load. If it does then you probably have the two stage clutch gone out of it. The same shaft that drives the PTO drives the hydraulic pump for the 3 PT and multi-power if you have that.
James In MO
05-02-2003 19:25:38
I would say either your releif on your pump is out of adjustment or your 3 point cylinder is in need of a rebuild or worst case your pump is shot You can check your pressure with a guage on the top of your transmission housing that is where I would start
