Chip...thanks for your reply. As far as I can tell, with the fuel shutoff rod pulled out, with the gear range selector in neutral, turning the key does nothing - no juice to the starter circuit. This suggests there is an electrical interlock associated with the fuel shutoff rod. Maybe not, but sure liiks like it. Like you, I see nothing of the sort - that's why I asked. :) As far as anything else draining down the battery, neither the headlights nor tail lights are connected, so leaving the lights on is not a possibility. Gauges might be a possibility, and I will check on those. My fuel gauge originally worked, but quit not long after I bought the tractor last year. As I said in my original post, I jumped the battery from a good and running truck, with still no sign of any juice flowing to the starting circuit. That suggests to me that it's not necessarily the battery since I'd have expected something if the circuit was OK except for the battery - even if just a grunt. I'll be chasing down the wiring tonight and will try disconnecting everything but what I know has to do with the starter. Thanks again! Chuck
