180 loses power at full throttle
RMagee
05-06-2003 19:29:18
My 180 has a LP engine and loses power when I need full throttle. Any suggestions?
Don-WI
05-06-2003 20:41:21
 Re: 180 loses power at full throttle in reply to RMagee, 05-06-2003 19:29:18
Does it sputter? Sounds like just the carb needs to be adjusted
Donovan from Wisconsin
RMagee
05-07-2003 06:33:21
 Re: Re: 180 loses power at full throttle in reply to Don-WI, 05-06-2003 20:41:21
Yes, it does sputter and will die if I don't back off.
Don-WI
05-07-2003 20:13:12
 Re: Re: Re: 180 loses power at full throttle in reply to RMagee, 05-07-2003 06:33:21
I have a 165 gas that did that when warmed up. It wouldn't die, but would sputter until I backed off the load or throttle, or pulled out the choke. To test yours, when it starts to sputter, pull out the choke some. If it recovers, then the carb high speed/load needle needs to be adjusted. Mine just needed a 1/2 turn out, and now it runs fine. Otherwise, try to get a hold of Big Dean, He would know more about it.
