1135 transmission shift fork
Bill
05-11-2003 13:45:38
Broken shift fork for 2nd and 3rd on model 1135...can it be replaced without removing the transmission? Have the top of transmission open up through panel on top.
Rob
05-14-2003 19:31:15
 Re: 1135 transmission shift fork in reply to Bill, 05-11-2003 13:45:38
Bill
If you have a cab you will have to tilt it back. Next, you will have to lift your pedestal (steering column, shift linkage, etc) off. Then your transmission cover plate. Then change your fork. Never broke a shift fork before, did it shift hard?
Good Luck
Rob
Bill
05-15-2003 19:02:57
 Re: Re: 1135 transmission shift fork in reply to Rob, 05-14-2003 19:31:15
How do you move the shift rod far enough to remove fork. Dosn't look like it can move either direction enough to remove fork. thanks
