Splitting Tractor Questions
Bill
05-17-2003 05:55:00
I am getting ready to split my MF50 and have a look-see at an oil leak (hydro oil) on the front end of the transmission and I have a few questions.
How do folks keep the engine side of the tractor from tilting side to side on the front axle pivot when split?
My tractor's transmission is a disabled multi-power (read mechanically locked in high w/no hydraulic clutch pack pressure) and I think all I will have to replace is the lip seal on the input shaft.
Anything else I should consider checking/replacing while I am in there? The clutch is in good shape.
Any tips, advice, etc would be appreciated.
Thanks in advance,
Bill
Bob
05-17-2003 17:27:49
 Re: Splitting Tractor Questions in reply to Bill, 05-17-2003 05:55:00
To keep the front end stable I place a piece of 2x4 on top of each side of the axle and tap them in between the axle and front casting. You say your tranny is locked in high with no pressure. That doesn't sound right. Usually when Multi-power fails, you lose high because that is the one that requires pressure to engage. Does the tractor free wheel down hill now or does the engine hold it back?
Bill
05-18-2003 08:53:11
 Re: Re: Splitting Tractor Questions in reply to Bob, 05-17-2003 17:27:49
Bob,
The tractor does not free wheel down hill and has engine hold back. If I park it on a slope, it does not move after the engine is shut down. The serial number of the tractor indicated multipower. There is a slot on the dash where the MP lever was. Either the transmission has been swapped to a "normal" 6 speed or the multipower has been mechanically locked in high. I don't recall the exact procedure, but I have read that one can weld the high range gear in such a way that it does not require the clutch pack to move it into position. I think this is what is going on with my tractor. Futher, the multipower pump is gone, but the bracket that held it in place is still there.
When I split the tractor, I will know for sure.
Thanks,
Bill
Bob
05-18-2003 19:01:01
 Re: Re: Re: Splitting Tractor Questions in reply to Bill, 05-18-2003 08:53:11
I would be interested to know what you find in there.
rlach
05-17-2003 11:40:54
Block it on both sides between the front axle anf front of engine.
rlach
