Removing rear wheels
Bob in NC
05-19-2003 18:42:16
I have been trying to remove the rear wheels from my Massey Harris 30, I have removed the 9 lug bolts.Pryed wherever I could. used an 4x4 wood to pound on the rim and tire. It still Has not moved. Would you tell me how it is done? I am new at this tractor game. Thanks for the help. Bob in NC
David (Scotland)
05-21-2003 06:33:09
 Re: removing rear wheels in reply to Bob in NC, 05-19-2003 18:42:16
Driving up and down seems a good idea or as folk have suggested and, we say in Scotland "If at first you don't suceed, use a bigger hammer heid" ("head" for the non-Scots)
Bob
05-20-2003 14:14:23
Put the bolts back in loosely and drive it up and down the driveway a couple of times, punch the brakes a few times, etc. That should loosen then a bit. Worked on my old green tractor, might work on other colors as well.
JED
05-23-2003 14:56:15
 Re: Re: removing rear wheels in reply to Bob, 05-20-2003 14:14:23
Nope, only works on green tractors. Have to drive in reverse for the other colors.
Call Dr. Victor is all else fails
05-20-2003 13:18:52
Victor cutting torch.
Bob in NC
05-20-2003 12:13:01
Thanks for all the help. I will try them and get that wheel off. Thanks, Bob in NC
Fred
05-20-2003 11:35:13
Had a similar situation with a JD 430. Used gas, pour a little around the hub/rim. Did it twice before it broke loose. Used an 8lb sledge and a block of wood to "tap" on it. Strongly suggest you do this in a well ventilated area or your wife will fuss about the smell coming from the garage. Also, I don't suggest smoking while trying this approach.
Sure you removed all lug nuts?
05-20-2003 10:43:34
Count them again.
Guy R
05-20-2003 09:21:29
1. Instead of pounding on the back of the rim (between the wheel and the tractor), pound on the front of the rim, right at the edge of the wheel (dont damage the bead area) Work your way all around the edge several times. Use a big sledge (ie 12 lb head with a 3 ft handle) Have a brave volunteer hold a block of wood against the rim. Hit the wood, not the rim itself, so you dont ding the metal. Really swing the sledge hard if required.
David B
05-20-2003 05:26:26
I been waiting for a reply on this. They should come off but some time you need a bigger mall. Try not to hit them on the edge and bend the rims.David B
