Super 90 diesel help???
Chris
05-30-2003 22:30:00
I am fixing up a super 90 diesel and was wondering if any one had a wire chat scematic??? Alot of the wires have been cut and something don't work. Most specifically is there is a red pto light? it says do not operate when light is on. what makes the light come on? there is also a wire coming from a sending unit on one of the hydraulic lines that was not hooked up? In addition the fuel gauge doesn't work.. is there a way to test it and is 12 v needed on the center stud of the gauge?? thank for any help... Chris
JIMLLL
06-02-2003 18:12:17
 Re: super 90 diesel help??? in reply to Chris, 05-30-2003 22:30:00
THERE IS A WIRING DIAGRAM IN THE OWNERS MANUAL.
I CAN FAX YOU A COPY IF YOU HAVE FAX ACCESS.
IF NOT, I'LL MAIL YOU A COPY
Chris
06-05-2003 20:31:40
 Re: Re: super 90 diesel help??? in reply to JIMLLL, 06-02-2003 18:12:17
Thanks alot, I got everything i need ( I think) thanks Chris
steve malecha
05-31-2003 05:42:07
The red PTO light is connected to the sending unt on the hyd line
