CHECK your thrust bearings!!!!!!!!
Chris MF135
05-31-2003 08:50:26
I like most have been dreaming of power steering,however have found that most of the effort put into steering can be removed with some maintance. Check your over looked front spindle bearing and bushings. To check the bearings remove them, wash out old grease and see if they spin SMOOTHLY while pushing it together. Mine went thump thump thump from the valleys beat into the races from normal use.The bushings (there are two in each spindle tube)should have 0.0035 to 0.005 clearace for spindle, in common term not tight but not real sloppy. They must be reamed or honed after installed for fit, I used a brake cyc hone and fitted by feel.A kit to do both sides bushings, bearings and dust seals is avaible from the sponser for$21.51 part number SBBSKIT01. Click at right side of tractor parts page on "here" for extended catalog.
My tractor has gone from a two handed steer to a spinner knob.
Hope this helps everyone as much as it did me.
Chris McKay aka Chris MF135 preveously known as Chris MF35
off the land
06-02-2003 09:16:28
 Re: CHECK your thrust bearings!!!!!!!! in reply to Chris MF135, 05-31-2003 08:50:26
Glad your efforts were time well spent. What model
tractor were you working on?
Chris MF135
06-02-2003 17:28:30
 Re: Re: CHECK your thrust bearings!!!!!!!! in reply to off the land, 06-02-2003 09:16:28
1966 mf 135, these bearings are in almost all massys and fords. bushings are the same as 8n
