Aux hydtraulics for MF65
Chip S.
06-01-2003 11:38:49
Finding the 5gpm of the 65's hydraulics ain't cuttin' it. Has anyone mounted and aux pump? I hear you can put one up front. How's it mount? I've also been thinking about one driven off the PTO, but I don't know that the trans/reservoir is big enought. Would like to get to the 20gpm neighborhood. Ideas appreciated.
Big Dean
06-01-2003 20:33:07
 Re: Aux hydtraulics for MF65 in reply to Chip S., 06-01-2003 11:38:49
Chip The front mounted pump is run by a shaft & adapter plate that connects the front crankshaft pulley. On the MF65 you need a special steering arm with an offset in it that is no longer available. You sometimes can find a used one off of an old MF50 or MF65. With the original steering arm you cannot turn very sharp to the left because the arm hits the pump shaft. I have had a couple of them fabricated at a machine shop.
Chip S
06-02-2003 06:39:44
 Re: Re: Aux hydtraulics for MF65 in reply to Big Dean, 06-01-2003 20:33:07
Thanks, Dean. Any chance anyone has part #'s for this unit? Any clues on where to start looking? I bet they're like hen's teeth used. Can the steering arm be cut and patched to work, or are we talaking about the cast Pitman arm.
David B
06-01-2003 17:05:55
Most better loaders of that day made for the M-F had front mounted pumps that drove from the front of the crankshaft. I think they did offer some PTO pumps but this ties up the tractor for PTO use. We had a good Davis loader with front pump years ago that was a great loader tractor, although a 4450 with MFD is not to bad today but there are newer and better out ther. The 65 hydraulic system was a high pressur low volume system that left some to be desired on loaders and remote cylinders.David B
