35 oil pan
Terry C
06-02-2003 21:21:51
trying to get pan off MF35 to change rod bearings,on a 3 cylinder perkins, have all bolts off but can't get pan to drop, wondering if something inside pan I don't know about that's keepng it from coming down?
C. T. in Oklahoma
06-03-2003 16:48:57
 Re: 35 oil pan in reply to Terry C, 06-02-2003 21:21:51
There is a bolt hidden near the transmission (the rear end of the pan). Run your fingers all around that area. C. T.
David
06-03-2003 10:41:53
Or else there is still a bolt attached somewhere that you've missed. I regularly find some bit still attached that I've overlooked.
Allan
06-03-2003 09:11:54
If all the bolts are out its just stuck, pry it
off equally with a couple of big screwdrivers
