Water pump leaking on 70 135
Bill in TN
06-04-2003 18:29:03
My water pump started leaking on my 135 diesel this afternoon. No problem. The front cover seaps a small quantity of oil, and I thought I'd replace the gasket while I have the water pump off. My questions are: Is this an indication that the front crankshaft seal is leaking?
Anyone know how much trouble it is to replace the front crankshaft seal? Do I need to pull the oil pan to do it? It's not seaping much oil, about a quart every 75 to 100 hours. Just enough to dirty the front of the engine, but it annoys me. What would you do?
Chris Holcomb
08-17-2003 17:29:02
 Re: Water pump leaking on 70 135 in reply to Bill in TN, 06-04-2003 18:29:03
yes, i have a 96 olds achieva, 6 cyl, 3.1 liter and my car was leaking coolent so i replaced the water pump, well i installed the water pump but then the gasket was leaking so i replaced it again, then it still leaked so i put some permetrex around it.Well now its still leaking and i have no clue why. Do you have any clue on what i could check or what i could do to stop it from leaking. Thanks for all your help. Bye
