150 power steering
david
06-12-2003 17:22:07
On a 150 MF when I start it up, the steering wheel turns to the right by it self. Was going to adjust the linkage to center the valve but the "turnbuckle" which should have a lefthand thread on one end and a righthand thread on the other, doesnt.Has something been changed or do I have to take one end loose and then adjust and put it back on till I get it right? Can I take the linkage off and work the valve by hand to see if its working? Any help is appreicated. Thanks, David
Big Dean
06-12-2003 21:23:49
 Re: 150 power steering in reply to david, 06-12-2003 17:22:07
The turnbuckle for the centering of the selector valve on the MF150 has a a fine thread on one end and a course thread on the other end. turning the adjusting nut one way will length the turnbuckle turning it the other way will shorten it. A half a turn on the adjusting nut makes a big change in the way it steers. If I can be of further help Email me
